I'm not arguing the superiority of a Superjet to a like-model Kawi... as I'd definitely prefer a Superjet, but based on the price/stats listed of the kawi in the OP... Is it worth picking up? Would at least like to get some ride time in and show up to wavedaze with a capable Ski.
The 1992 750s have the least desirable engines and ignitions. Their pumps do not work as well as Yamahas in rough water. If it is loud then it has no waterbox.
Kevbo, you crushed my dreams and ruined my hopes of going pro....
JK. Suck it.
p.s. on another note: You seem to very knowledgeable, but you have to be the biggest negative bumble bee in the hive here.. man oh man, search on all your posts... Gimme a goddamn smilee face there kev'ster!![]()
Don't listen to this nonsense-- the 92 is ported for the best bottom end. You can add a fixed timing advance or find a CDI out of a '96+ SXI or '03 SXR and have nice timing curve-- it is a straight swap. Put a single 44 or 46 mikuni, factory limited pipe and mill that stock head that thing will have loads of bottom end. That thing should already have an 82mm reduction nozzle, but could prob be bored out a tad more if you are looking for the most bottom end.
