08 superjet bottom deck?
RiverRat
Louisville, Ky
I am tossing around the idea of doing a 08 style superjet bottom on my x-jet. I am not a big fan of the REV bottom with a 62t platform b/c I think it is too squirrly. Riding it in the surf just sealed the fate of that bottom for me. It could not carve and I was always fighting the boat. It is ok in flat, but all around it is just to difficult to handle and have fun with.
My options are:
1) add a little weight to it and swap the REV bottom for a sqarenose bottom deck. I was thinking of adding some mild sponsons up front and just paint it black.
2)Have WCF buld me a 08 style bottom deck. It should be about 20lbs lighter than a OEM conversion bottom deck and have the added benifit of the new bottom deck design. However, I have not been on the 08 bottom.
From those that have ridden both, what do you think? Both will be shortened 2in in the rear. I am sure it would be nice in the surf but I hear mixed reviews in the flat. I am pretty much just a flat water rider.
Any comments would be appreciated. This decision is bugging the crap out of me.
The 08 bottom is pretty nice. I rode one last Sun in the surf. You get built in sponsons and you can even add tubbies to it like Serlins boat that Blowsion built. Also, you get the set back pump. The Stock ride plate is jenky though... looks like Yamaha just took a regular one and drilled diff. holes to make it fit.
If only Yamaha changed the bottom deck and left the pole asd steering the same, maybe so many poeple would be happier with the 08...
I vote for getting the 08 bottom!
(just my 2cents)
RiverRat
Louisville, Ky
Is the intake grate the same? Just trying to get all the info together so I know what all to expect from this built. I know I will need the longer drive shaft as well, unless I set the motor back a couple inches.
Big Kahuna
Administrator
Tuscaloosa, AL
Why build a race hull bottom for a flat water ski?? The 08 is a great hull and design, but it is build to carve the water, real similar to the SXR. I had a hard time just getting the one I road to jump out of the water.
