Blaster 1100 conversion build!
Well, that completely sucks. That is one of the reasons why I rarely buy anything from anyone used anymore. You can't friggin trust anyone.
Good luck with the rest of the build. I can promise you one thing, once it is done, you will love it.
SM
They actually run really well with stock carbs set up right. You just need to get the pre 98 non cv carbs. Those carbs with flame arrestors and adaptors, running the stock jetting, works really good. No, they aren't as good as a triple set up of 46s, 48s, but for the money, they work good. Plus, with the accelerator pumps, you don't need a primer or choke.
SM
tshank123
Yo hablo ingles
Vegas
I've got an OEM 44 rack from a GP1200 I'd sell you cheap. Needs throttle shafts replaced, but I think you would need to replace those to get it to work on a Kawi setup anyway.
The ski we built for John Grinager (johnfrmcali) had those stock GP44s and it ran great. That is the one on my youtube channel. Takes some work to get them set up for a Kawi, but definitely better than the stockers.
SM
Replace the shafts and had to mod the intake fittings because they are designed to work 2 into 3. We set his up to have a fuel pump on each carb. The brass fittings on the Yamaha carbs screw in, so Joe ended up having to sodder some t fittings into elbows. Nothing too scientific, just a process. But worth it, OEMs 44s aren't cheap.
SM
Painting compliments to byeai! (Thanks babe)
Sparkly . Love it.
I will let u no about carbs . Thanks.
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
She is alive! After hell and back , new top end, fresh paint. Replaced pretty much everything. Super stoked for wavedaze! Hope to see everyone out there!!!
Huge shout out to byeai and chadgnarley for all the help!!
Gas tank is done in plasti-dip. Its a form of spray paint. Although I would not recommend plasti-dip on it as it is not gas friendly. U have to be careful! Lol but thanks!!
Byeai
"Cheetos-Man"
Melbourne FL
That thing runs post a video for God sake about time :)
