12 vein pumps
I am considering getting a mag pump for my set up. My question is, would I see a big difference in pop? Or should I save the $400 (buying 12 vein stator only) and wait until I get a bigger motor? Currently I am running a 61x, single carb with ada head, 144 pump with solas concord 13/17 impeller. I will be using it on a gen 2 glass bob with trim. Wanting to try to backflip off of a boat wake.
Yami-Rider
TigerCraft FV-PRO
Texoma
pointless swapping a 61x for a 61x/62t if there both stock
I own both. Definite power difference in the 61x vs 61x/62t, More potential. Mag definitely helps, but from what i have experienced they are much more beneficial on higher HP engines.
Do you already had MSD enhancer, pipe, reeds?
I just figured before I installed the pump and motor etc if i would see a difference go ahead and get the 12 vein but sounds like msd, reeds and a jump start on a different motor set up would be more beneficial
Quinc
Buy a Superjet
California
Night and day difference on bottom end on my built 61x when I added Boyesen carbon reeds and an msd enhancer. If you buy the reeds sign up as a sponsored rider for the 30% off code.
Schmidty721
someone turf my rails
WI
Keep in mind your Solas Concord is not a big hub impellor. If you decide to go to the Mag pump you will have to buy a new impellor as well to work with it.
tor*p*do
Squarenose FTW
NW NC
Loved the way my solas pump ran, better hookup, better power
hated the way it ate bearings and locked up, trashed my midshaft
so I went back to stock
