No but I possibly mixed up the springs so I'll just give it a testDid you change the needle and seat size, if not then popoff pressure is probably not your issue.
Unfortunately it just has the primer and has the choke disconnected but left wide open. If I pump in the primer at full throttle it will rev up to full throttle but only for a short burstI'm confused. It sounded like you had a choke plate on your carb? Do you also have a primer plumbed in? If so. I would totally delete the primer and just use the choke for starting the ski.
If you ride at 1/4 throttle for say 20 seconds ds. And then hammer it open. If it dies. Like shuts off. It's lean in the mid/top. If it stumbles and powers through. Your rich in the top/mid. If it pulls right on through. Your good
Sorry about the confusion.Got no idea what he needs to do. Start from square one is what is do. But once it's running. That's how mikuni says to test the mid to top end. And how I've always done it. And what works for me. If it's rich you can turn screw or adjust jets. Same with kean. If you gotta go more than 2 turns one way or the other, go up or down that way a size in jetting. Depending on what thread adjusters your have that is.
I was just confused about the primer and choke combo
