Vumad
Super Hero, with a cape!
- St. Pete, FL
Yes I got it started, my buddy had to hold the crankcase drain all the way open while we turned it over. It finally started so I don't know if it was flooded that bad? Let it run for about a minute then tried again an hour later. Had to do the same thing.
Disconnect the fuel when you shut it off. If it works fine, then your needles are leaking and flooding the motor. Either way, sounds lke you need some carb work.
