Freestyle 2 New Builds for 2018 Xfr and 2He
Plano, TX
Theses carbon pole tubes are sexy. I’m waiting to hear back from TC if I can get the carbon upper without buying the whole cbx pole
Plano, TX
So you can’t buy the carbon upper by its self. Sold as whole pole only. They say the rest of the pole is different. That’s a drag but since I break everything that’s one less thing I have to worry about
I’d put money on you breaking a carbon pole, lol.
Plano, TX
@tntsuperjet finished up my Dasa this weekend. Taylor said my Rickter should be in any time now. Everything is coming together so far. Just need to buy a pipe, pump and set of carbs
Plano, TX
Unboxing was pretty exciting since I wasn’t sure what it was going to look like
They forgot the front foot hold so I’ll just have to add a strap up front instead.
It didn’t come with any inserts so I guess I’ll put the ski together and ark where all I need them and use my own. No scupper tube either. The bulkhead is like my dvx and water just flows under the tray to 2 scuppers. One in the back and one in the pump cavity. So much for using a ball valve
Weighed the pole and with chinpad, Carbon tubes and ovp steering it was 11.5 lbs. hull came in at just over 90lbs and add another 8lbs for the hood
It is such a pretty hull. For now anyway. What do ya think? Swap the blue pole bracket for a black one?
I like your XFR! I'm building an XFS carboncore right now that looks very similiar. My Hull came with carbon inserts for battery and fuel tank separate for me to glue in if I need them, I'm surprised yours didnt come with them to.0106181049.jpg
I can get a pic of the inserts tonight. I probably would have traded pole brackets but I drilled the threaded side out in order to run pinch bolts already.
