- NYC/Long Island
Just got a barely used 2010 SJ from a buddy. It's immaculate. All 100% stock with maybe 25 hrs on it. I've grown up on a Kaw 650 and 750, had an 800 and ridin' all kinds of stand ups including a 2011 and 2013 SJ. Had a 550 and ridin' early 90s SJ's. Rode an awesome Freak this past weekend. So I'm used to riding and know the feel of a variety of skis and have never had a churning consistent wobble. This 2010 definetely has a weird wobble. Again...it's not the aggressiveness or lack there of because it is in a straight line that this rhythmic wobble takes place as those who have experienced it know to well. Those who haven't experienced it will say I'm crazy, haven't riden enough, be more aggressive, move my stance, etc. but it's 100% there. Has anyone solved the problem 100%? Did cutting the rear rail fix it completely? I hate to whittle away at an almost new ski. Love to hear an update from u guys including the original poster Fairlane. Let me know.
Thanks
Andrew
Blue71
Theoretically a 12 vane magnum pump would help with chine walk. I believe it's caused by the torque of the prop (a twisting motion acted on the water exitting the hull) causes a walk or rock between either the chines or tubbies. Don't believe me? Before you get on a plane, loosen your grip on the handlebars and let the ski do what it wants. Blip the throttle. You will notice the ski bumps to the left.
You can install a 12 vane magnum pump on the ski; I think that would reduce the torque on the hull by helping to straighten the water outlet more than a 6 vein pump.
It's a combination of the narrowed rear, the long sponsons and more aggressive chines on the newer hull. I don't think any hull is any different from the next; I assume the differences are the rider itself. Mostly weight. A heavier rider would have those tubbies wetted at a slower speed than a lighter rider. It only happens on glassy water. It doesnt happen on rough water because the symmetry of the hull isnt fully wet where it can rock between chines.
I used to experience this rarely on my 2008, most likely because the constant choppy conditions I rode it in. When it did happen, i'd just power through it or let it do what it wants. Never did I feel like it would buck me off. If it's worth your time, try to set the exit nozzle with a little up trim. If I remember right the 2008 had some adjustability.
