x2 Same way on my predatorLooking good, don't forget to glass the underside of the foothold to the bulkhead, mine was not done.
Plus, its 4lb foam! Its really strong. I spent an incredible amount of time cutting the Pink foam and cramming it into place, its crazy solid too! Plus the 1708 biax, this tray is concrete.Looking great! Glad to see you using two part foam. It adds an incredible amount of strength!
Footholds????????????????
nooooo…you fill in the mounting holes?
Never owned a crash, Rickter has a plate that mounts to the side of the hull. There are bolts with stringer washers that you can see. I thought you may be making this one just like the SN!!!!!!!!!!!!!!! Recess pockets with no footholds!!!!!!!!!!! Shots Fired.What? No haha they are slots in the sides of the tray. I guess you just can't see them. The mounts fit fine. What is this, amateur hour?!?
