2015 fiberglass Phantom
I've got a somewhat similar motor from CPT. 4mil PHP LW crank, probably similar porting, main difference is that it's resleeved to 89mm. With a pfp, dual 46 and an enhancer, I was using a skat 7/14 with a 92mm nozzle bore. It wasn't dialed in, but it was in the ballpark. Hope that helps.
alright... I just did a bunch of searching both here and on Google, but can't seem to find it anywhere. Is there some type of cross reference chart that explains the numbering systems between Solas and Skat Track props.
I have no idea how Skat Track 7/14 & 7/15 props compare to a Solas 11/14. Which is more aggressive/taller or lower end??? So confused... @DAG, I guess I need on of those impeller pitch things...
DAG
Charlotte, NC
Yeah props are confusing, I sware they do it on purpose so we have to keep buying props to fine the one that works for us. I would be happy to get you a Guage but unless you are truing up blades or repitching I dont think you will find them useful. Comparing props between manufacturers is apples and oranges. I suggest you pick a brand you want to work with give them a call and explane your setup and they might be able to get you in the ballpark. Not a lot of people run a big pump with a small motor. I believe whatever prop you start with will probably end up needing a repitch bace on the first water test
