2016 Phantom Island Tribal Build
NC
Before you put drill bit to pristine lay up, whisper "remember: this hurts me a lot me than it hurts you".
Spokane,wa
All strip down...what do guys thing it worth...I know the money and time I put into to building the hull.
What left
Intake grade
Pump shoe
Ride plate
Blowsion lower hood and nose piece
Bob holds
front foot holds
One way versiplug
Drain plugs for the tray
Tubbies
Fuel selector
blowsion hood hooks
A/m handlepole
Spokane,wa
I was very nervous and very pain full to put hole in my hull but it done,took half the day.I think I measure 20times before I finally drill the holes...haha..
Had cut the backing plate
Here my rrp pole all mounted
oakland
Yes it will or just epoxy the stock e box mount in the location you choose or drill some more holes and through bolt it if running a ratchet strap make sure you are below it's mounting location
Pablo
sqeez bth levrs & lean bk
georgia
Behind carbs. It should fit. Measure thickness of ebox plus bracket and some nylon washers to space it off side of hull a couple mm. Measure and test fit distance from hood lip too for batt cable clearance and distance to run to starter/battery.
Edmond ok
The cold fusion mount should fit.. Do you already have one to try?
That or you can just bolt the ebox straight to the front of the tray using the 3 taped mounts on the back of the ebox. Like how they are mounted in raiders.
Spokane,wa
just got a pm from jm,i'll be installing cf mount for my ebox moving on with the build
