Injection
This injection system works on principles that a man Named Smokey Unic came up with in the 50's. Many companies such as ford chevy lockheed martin are looking at or are actually using it. Unic's idea was to so pass fuel through a series of high pressure valves breaking down the fuel molecules, until it became totally vaporized. This inturn would be injected into the cylinders. Result, a slow even burn, 50% more horsepower, and 40% fuel conservation. He could never get this process down 100%, due to the lack of presicion contol(computer). These days that has change... This is similar technology that The F-22 raptor works on. First plane that can do mach 2+ without an afterburner. This injection system shown in the pic has been refined, by companies like Pratt & Whitney, ATK THYOKOL, GE. I am currently working on a tooling mandrel(wrapping mandrell) EXIT NOZZLE for the new space shuttle. I cant say for sure but i believe it will use this similar technology. There are over 100,00 .0003 in the upper exit chamber of this part......
This Guy is good...Man That an awsome talent to be able to identify a part just by its hole placement and pattern...Kelly Johnson would be proud!!!!!....And for the other one who said to many things that have been mentioned do not add up......Well lets see. What does not add up. The crank, pipe, pump, cylinder, intake, fuel, hull, hi temp alloys have all been mentioned......How hard can be.....I cant hold your hand and walk you through it........To me it sounds like.....I just think you don't understand it!!. Your probably the same guy that watches OC CHOPPER and thinks wow there precision......hahahaha. Gotta love when the rear fender sits off centerline 4 inches after they got done welding the hell out of the frame and can't figure out why......You sound like that kinda guy.......Well lets just say it requires just a little more skill to go 5,000+mph. I think the machines might be a little more complex than a feakin watejet machine and a bridgeport........ So when your mechanical vocabulary can exceed cnc billet. contact me will have starbucks.
