- Jersey
penguin and parrdaddy should be able to gfigure this thing out... one's an engineer, the other is a rocket scientist.... i think that more than qualifies them
After 20 yrs of riding, racing, cutting, fiber glassing, machining, breaking(2) modifying, big boring, cussing at, and sinking X2's. I decided to build 1 more X2!
UNFORTUNETLY I HAD A 2 PAGE WRITE UP ON THIS SKI. AND IT WOULD NOT POST...
FOR ALL THE PEOPLE THAT THINK THIS IS NOT POSSIBLE. OR THAT I'M ON DRUGS.... OR ERIC MALONE SHOULD USE THIS instead OF A 1000cc MOTOR..
WELL LETS BEGIN....I HAVE BEEN A TOOL AND DIE MAKER FOR LOCKHEED MARTIN FOR 15yrs. Working for a place of this magnitude offer accsess to state of the art 5 axis horizontals, VTL, JIG BORES, SURFACE GRINDERS, EDM, ELECTRO BEAM WELDERS, LATHES!!!!!
HERE IS HOW ITS DONE.......A very low estimate of 212 at 14,500rpm....THIS HP NUMBER WILL GROW!!!! (250+) SOLID 1 piece vacuum forged INCONNEL750X crank. 2 piece vacuum forged 7075 connecting rods, using radial polycrystaline boron nitride ceramic bearing. Crankcase is watercooled and stuffed, crank to case clearence is .003. Graphite 50H Stuffed Pistons. INCONNEL 718 sleeves, Inconell 625 rings. Taking cues from the P-51 Rolls Royce Merlin v-12, this cylinder uses 12 digital control water injection points. 72 .004 holes have been drilled into the piston crowns exiting behind the ring lans. High compression direct cylinder injection. 90% nitromethane 10% Hydrogen Peroxide over Silver Mesh
PUMP/ NOZZLE AND PIPE ARE DIGITALLY RPM CONTROLLED TO EXPAND AND CONTRACT. Like an afterburner of a modern military jet. COMPOSITE/Mercury filled drive shaft. Solid titanium pump using two impellers Push/Pull......ANDDDDD THERE IS OH SO MUCH MORE TO THIS SKI
THINK OUTSIDE OF THE BOX.......BECAUSE YOU CANT BUY IT IN A STORE DOES NOT MEAN IT CANT BE BUILT ...PICS COMMING SOON.
And For all the People that make the wise cracks....I understand, but consider this, 1970's technology produces 20 million horse power through pumps and fans (Space Shuttle) SSME alternate turbo pump. As far as machine/motor/metal technologies, The AEROSPACE INDUSTRY leads these tech fields by 20+ yrs. Thats why B-2 bombers cost 2 billion each. Thats why the Space Shuttle is still the MOST COMPLEX MACHINE ever built.
That's a little too much RPM to be effective...A very low estimate of 212 at 14,500rpm...
in the pipe he's smoking!
You guys are all knocking him. WTF! Even if you think he is BS'ing you should atleast give him a chance. I'd like to hear the rest of all of this but if I was attacked on the threds and only had 2 posts I would not post anymore and not come back. It sounds corny but cant we all just chill a little bit on the new guy to the threds?
i asked some legitimate questions and when your first post is claiming to be the end all be all of X-2's, naturally people are going to give him a hard time
True that, but some people however cool they really are, asking questions is one thing but just saying BS and telling him it's imposible isnt really cool.
I yes have called someone out on here but that was to get results not ust to say something is impossible. It might be just me and a small few other people but if your making those kinds of rpm's and it's all geared twords hp I think that # is possible. Some people just dont want to stray away from what has worked for them in there skis.
What do the following people all have in common?
Nicholas Copernicus
Galileo Galilei
Johannes Kepler
Isaac Newton
Christopher Columbus
