3 Degrees in the right direction?
jeepmark4x4
Backflip, weeee
Marietta, GA.
This is an oooolllddd thread but I'm doing some last minute tune ups to my 61x...
I'm running a stock 61x that I just put together and wish to get alittle more UGH out of it for the Daytona ride. I heard to move the stator plate clockwise to advance the timing but I have been reading to move it CCW. Just want to clear some stuff up before i take the timing light to it.
I want bottom end! No high end runs
Im running:
stock 61x with 650 electronics that has the lower rev limiter
Caufman sizzler pipe.
Mouthfulloflake
ISJWTA member #2
NW Arkansas
Hey Jeep mark,
I want to know how this works out, as ive got a similat set up that hasnt been ran yet.
Im running:
accbr
addicted
Lexington, KY
Im running:
I have the same setup except I ported the cylinder. I advanced the timing 3 degrees. I've put a few tanks through it without any problems. I don't make many long WOT runs on it though. Never tried it without the advance. I set it that way when I built the motor.
edit - took the top end off this past week, and it looks fine.
chrisdoc0608
insulting
rocky mount, nc
ok so counter clock wise 3 degrees.... what did you use to measure the degree marks? ive got one of the degree wheels for the seapoos wonder if i could use that. oh yea, and what exactly does it mean by advance timing, does that mean spark earlier?
chrisdoc0608
insulting
rocky mount, nc
cool, but still courious as to what advanced timing means... i was under the impression that it is fireing of the cylinder earlier than stock settings... how does this relate to performance.. better acceleration, more power.. how noticeable is it.
Mouthfulloflake
ISJWTA member #2
NW Arkansas
you will for sure notice all 3 of those things combined.
careful though, you can no longer clamp the throttle and run WTFO if you any compression, RPMS, or lean-ness.. issues.
haha im gonna do it as soon as i get my flywheel sent off to lpw... im hoping for some very nice noticable power after these two things and a bored nozzle.
Roo
it's all good
for what its worth...
all i can say is wow!!! i jumped into this today... took the flywheel off and i actually had the stator retarding the timing! brought it back to the dash mark, then +3 degrees and damn, there was the extra little umph i needed!
i am on a small in land lake and only do freestyle - never any WOT runs.
chrisdoc0608
insulting
rocky mount, nc
so is there anything i can do to find out how long i can punch the throttle like if i want to chase down a boat or something like that... also what do you guys do about riding to your riding spot? just keep it at like 3/4 throttle or something?
Mouthfulloflake
ISJWTA member #2
NW Arkansas
have you ever ridden a stand up?
I hardly ever cruise at more than 40% or so throttle, always blipping it, slowly up to a wave, turn, carve, wave, a few seconds of WOT limit is NOT an issue at all to me?
