nearing the end!!
I've gone back and forth on it as I mentioned earlier in the thread - but I settled on keeping it "pure 550". Trying to see what a 550sx with a modernized hull will be like, most likely fun!
Got the chines shaped up today! Never really had much extensive experience with body filler, so I had to learn how much to mix up before it would harden too fast for me to apply it. I learned that pretty quick lol!
layin' in the goop. Just kinda figured on adding extra, so I layed it in heavy, all nice and deep like.
Once everything dried all nice and hard like, I set out with 46 grit paper, and I had a 4" and 3" set of cylinders (Packing tubes from McMaster). First I chipped away all the major excess with a paint scraper, then went to town with the 4 inch tube. This about "matched" the radius of the existing chines. I didn't think this looked cool enough, so I put some 46grit on the 3" tube and went to town. This gave more more of the classic superfreak'esque chine.
I then needed to blend the front sections in with the existing chines. I did this first with the air grinder, then did fine detail work by hand with 46 grit again.
I think they look pretty good!
I'm going to do like fastGTfairlane did with his and just lay 1208 over the entire bottom sections. I'm not going to do the whole ski's bottom though, just 6" wide strips that will extend about 2inchs past the blended section.
Gettin there!!!
Now I'm just waiting on some epoxy resin to do the final layups.
