Moar Sanding.... lots and lots more!
Well I have the hull at the shop were I'm going to paint it now - I've spent the last two nights after work sanding it and it can easily take 2 to 3 more! I rounded out all the edges on the hood and it looks great! No pictures tho - sorry (it's not that interesting anyways, lots of fiberglass dust lol).
In other news - I've been riding my 440 a lot more lately - My mentality is any time spent on the water is good time! Don't matter if I have a 440 with 120 psi compression or a Dasa 1200 in a rickter lol.
Last weekend I had 2 main issues with the 440 that were game ender's - I was getting the
shocked out of my finger from my trigger throttle so bad it would put my arm to sleep, and the engine would cut out after hard landings and after a while, it just wouldn't run at all if it was in the water (but sure enough as soon as it was beached or on the trailer it would run like a champ... wtf?). So to hopefully alleviate these issues I made sure there was a very good ground from my battery, to the ebox, to the motor, and to the carb (which is the only thing connected to my throttle cable technically...), not to mention the ground line that's already there to the starter (0 AWG!) The new ground cable is 4AWG stranded with good terminals so hopefully I can enjoy a good ride day at Brigantine this weekend!
I pimped out my 440 a little and I'll just post some of my work here since I may end up doing similar things to my 550!
Installed a limiting rope -
Made my own custom lower bracket - I wanted it to be very flush, so I used 1/8" angle aluminum and cut and filed it to a shape that I wanted. I used 2 1" SS carriage bolts and nylock'd 'em on the inside. Up top is just a eye bolt, I just tied my rope since I like knots, and the handy side effect they have of being adjustable
. I used a 24" rubber strap and kept the "S" hook on one end and bent it to tightly fit around my pole pivot bolt. The other end has a locking loop which slides nicely on my rope.
Also installed a foothold (in the process of it actually!) I ride goofy foot, and After having the 440 out last weekend in some 5-8 footers I decided to throw a strap on it since there's 5 footers predicted for the Brigantine beach bash. Figured having the ski connected to me albiet not much power behind it, would still be better than not!
Took a few stances averaged them out - moved it back an inch (Since I'm still a n00b I like to ride farther forward than I should!) and started by cutting out some turf rectangles
-I took my dremel and sanded the area in the rectangle holes rough to fresh hull. I then plotted and drilled the holes. My buddies use these inserts from McMaster (MCM# 92105A100) which is basically what Blowsion sells for a lot more.
To keep the threaded insert's threads clean, I sealed the tips of them with a tiny piece of duct tape. This ended up working well!
I then applied cab-o-sil to the holes and nearby area
And drove the inserts home!
I went over the inserts with a toothpick and just made sure there was a layer of cab-o-sil over the flange to give them a little something extra in terms of resisting pulling out.
I'll throw the foot strap on tomorrow - I got a Dakine Supremo so there's a lot of adjustment! I'll probably run it a little loose to start?
Probably going to install some homemade hood straps tomorrow! I have extra buckles from the supplies I bought for the 550 project, all I need is the nylon webbing which REI just so happens to sell! Lunch time trip tomarrow... That should about do it for this 440 then. One day it may be getting a 550sx engine, so it's gonna be pretty nice by then!
