Day 11... finally laid some glass!
Well I was tired of being destructive so I decided to be constructive.
Started out the day making some final sanding to the rocker - when you do the 2" parallel slice technique it creates a sawtooth texture to the hull surface, as the one upstream moves away it's closer face becomes "higher" than the down stream's near face. Basically I got the 40grit 3" disc out and sanded a lot until it was relatively smooth.
Next I made some paper templates which I used to cut out all the fiberglass sheets. I decided to split up the bottom into 3 pieces so it wouldn't stretch too much on the concave faces and form air pockets.
I decided to go with 3 layers of 1708 to reinforce the now split apart nose. Hopefully this gives it some strength for those 6" water nose stabs.
I test fit the cut out's to make sure I didnt royally
up the templated cut outs.
Like a glove!
So now I prepared the bottom for all the epoxy resin that would be layed into the cracks. Duct tape fit the bill
Then I mixed up a nice penut butter batch of 3:1 epoxy resin and cab-o-sil and spread it out, and got in all nice in deep like on those cracks. I stopped after it was pretty well covered cause I'd be painting a layer of epoxy resin over the whole thing anyways for the bottom of the mat, and the mat is flexible enough to fill any voids.
Finally started laying some glass! fun. I gave the center section an overlap of the two outer sections to help tie everything together (hopefully)
The first layer looked pretty good, Basically just used this method:
Paint on a layer of epoxy, lay glass, painted on a layer of epoxy over that, skweegied it until it became a solid translucent sheet, then moved on to the next part. for the 2nd and 3rd layers I would repeat exactly the same. after the 3rd layer I rolled the
out of it and came up with this.
With the roller.. I was afraid I'd lose it to the cause after reading none to good of a story about salvaging them. Well I beat the game! After I finished rolling, I stored it in a bucket of acetone to soften up the resin. After 10-15 minutes of soaking I blasted it with my compressor (sits at about 145psi) and all the resin was removed leaving a fresh roller ready for tomorrow! Yea my friends call me Jewish.
Tomorrow I'm going to do the engine bay and foot hold area's left wall reinforcing - 2 layers of 1708 on each should be adequate? I'll do a 1" overlay 90deg part in the engine bay to tie the floor to the walls.
Hopefully I can keep this progress up! I want to be riding in june!
I'm also thinking of getting a shortened pump cone, anyone think pump nozzle boring is worth it on a 550sx? I'm just looking to get the most bottom end out of this little engine as possible for as little lol - I hate working on engines.
Oh yea forgot to add - this is the first time I've ever fiberglassed lol - how'd I do? Still getting a feel for this composite working stuff, but I like it! Always wanted to build a positive mold carbon fiber mountain bike!... just may do it one day.
