- 1 Mile High in Colorado
Alright, found a flow control valve for $40 shipped. It is the standard jet works model - preset to 4.5psi but able to be shimmed internally to any cracking pressure you'd like. I'll leave it as is probably.
I've looked for the OP steering nozzle but have not had any luck finding one.
One thing I've noticed that was sort of funny is a 3" heavy duty rubber pipe coupler (sold at the big box home stores) fits on the nozzle perfectly. I might try this to play around with nozzle length if it works - I could technically have any length I want with the turn of a hose clamp! Anyone ever try this?
I have the Mariner style waterbox - I need to modify the outlet with a 90deg aluminum fitting however as my engine bay ceiling in that area is getting lowered enough to make the current vertical outlet not work. The internal baffle system also broke loose - so I did a cut straight down the middle of it on the wall and halfed it - I'm going to have my buddy re-weld the baffel back in place and weld the waterbox back shut again.
Anyone have any opinion on head gaskets for these? I'm thinking of going copper with 1211 sealant, I'm getting the head milled by #Zero for higher compression and I'll need a new headgasket, I've heard both fiber and copper are a good choice - but that copper is slightly thinner, but more of a bitch to seal, and a coat of 1211 is needed to create a watertight seal.
