I can see the light...
The light at the end of the tunnel is nearing!
Got all the reinforcing done now! just a few little tidbits here and there...
It all started with templating the
out of my last few yards of 1708. Gonna miss that stuff! Good thing my buddy lent me his leftover 3-4 yards to do the bond rails! I absolutely abhor 1208 - that
is horrible and flakes apart like an overcooked fish dinner! I'd much rather sacrifice the weight savings (that is actually arguable, since you may need two layers of 1208 to equal the strength of 1 layer of 1708, but 1 layer of 1708 will be lighter than 2 layers of 1208!)
Anyways...
The finished hood (11 pounds before final sanding...)
-I think I probably went overkill on reinforcing the hood, but it really is strong as
now!
And tray
-The tray has 4 layers of 1708 in the foothold and main tray area, and I added another 2 right under the foot strap location for more material for the inserts to bite into!
-I may have mentioned it already - but adding those triangular wedges to join the rear gunwales to the front section increased the stiffness about 1000000%! They are practically immobile now were as before if you tried to squeeze them inward or outward you could to some extent!
And finally the nose being attached!
-A nice layer of peanut butter cab-o-sil/epoxy mix will hold it in place after it cures, and I'll internally bond it with a layer or two or 1708 (Top deck to bottom deck with a 3-4" wide strip).
-The floor under the pole bracket mount is appx. 6 layers of 1708 thick. Should do the trick?
Everything is going well - didn't get my tubbies laid out yet, but that's what I'll do tomorrow. Thinking of possibly abandoning the 2 layer design to emanate the newer designs with rear rocker - reason being is that I'm only going to use 2 layers of 1208 on the tubbie, and if I do the whole side that will leave the side relatively soft since there will only be foam under the glass. I'm thinking of just making a single longer tubbie that has a stepped shape about halfway to sort of imitate the rear rocker.
Still definitely adding a matrix/superfreak bond rail though! This will hopefully help imensly with handling?!
Also I will be adding my 5/16" fiberglass rod ($5 item from McMaster!) to the bottom to make deeper chines! I think that will be a nice improvement - not overly deep, but along the lines of a superjet/superfreak. Being that they are structural fiberglass and not wood, I'm more confident that this will still be a good beater ski and not one that needs babying!
