Hello, first post here. I've been browsing the forum since I bought this boat this seems to be the best place for Yamaha engine info that I've seen on the web. Wasn't exactly sure where to post this, so please move it if I got this wrong.
The boat is a 10ft aluminum hull with 1/2" UHMW (Teflon) on the bottom like a skid plate and weighs in around 1000lbs loaded fuel/two people. These are great for running rivers around Calgary where I live and is a ton of fun. It has a 701 61x engine, but has low compression (125/130). Assuming it's down quite a bit on power, stock hp is 62 from what I've seen, guessing it's sitting closer to 50 at this compression. I reached out to Impros and installed a Solas 144 Stator, Solas SS wear ring and Hooker 9/15, which made a huge difference from the worn out stock setup. It could still use some more punch though, I was going to just rebuild the engine back to stock specs but after browsing around and seeing tons of different options. I'd love some advice on which direction to go.
Has to be reliable as some rivers here, if you lose power you are going to have a bad time and could be in some dangerous situations if you are dead in the water. I've read that a pipe really wakes the engine up, but it's not an option as the front of the OEM Yamaha pipe is maybe a 1/8th inch off the firewall (see pictures). Anyways, here are the options I've researched on the site and others.
1. Rebuild to stock (maybe add some bolt ons)
2. Have a Jetmaniac engine built
3. Swap to 760
Keeping reliability in mind, what would you do?
Here's a video of what the boat drives like currently, top speed up river is 30mph and down is 35mph which feels plenty fast. I wouldn't complain about a touch more top end so I don't have to be at WOT to maintain some speed.
3. Swap to 760
