701 Rebuild Threebond around Crank seals?
Edit. I guess they could have meant cardboard. Or maybe chewing gum. But they expected techs to understand how to read a manual. From the beginning
That number is superceded to yamabond
2.2l 4cyl I-Ctdi Honda, Mercedes-Benz Eruo 4, VW 3.0 in the Lupo, all in the European market… not sure how many others, lots of diesels in the European markets…
Yeh. Lil guys.
Aluminum is softer. Grips better. Mic your x or the cases with the crank out. You'd be surprised on the flex. The case takes the shape of the bearing. The seal isn't going to slip if your cases are good. They aren't going to leak if your cases are good. If your getting leaks and you seal it with goop, you have other issues your masking.
Cat wanted to hire me. Cool company. Union tho. And corporate as hell.
Sent from my SM-G970U using Tapatalk
