- Australia Melbourne
ski looks siiik! i love how u used those high pressure water fittings! i have them on my rx7!
cheers mate-
for single carb x-2 the SJ filter is unreal!
yeh out whenever we can mate...hahah the green dash suits the wheels.. u been riding much or to cold? im on holidays soon so we will have to try go for another ride soon
cut the rear edges dow to the turf bro, they will not be very friendly to your body if you land on them
stock length plate (shortened shredmaster) d-cut, and tapered to fit the 2" cut on the hull. the tunnel was cut to the seat latch and the tow eye moved to the side of the tunnel. sides are cut at the top of the slope then tapered down
Very happy with my new mods so i figure i would share some pics.
- Twin 48 RIVA powerbombs on R&D manifold (replaced the single 46 buckshot)
- V-FORSE Reeds (repace the carbon tech with stuffers)
- Angled reed spacer (replace the JRE one)
- SXR Factory wetpipe chamber (repaced the factory 650 chamber)
- 9ltr Go kart tank with twin fuel pickup.
- Straght through waterbox, RHS exit (replace the westcoast one)
- Lees high comp aftermarket head
Uploaded with ImageShack.us
did you notice a big difference with the duels and sxr chamber?
If you don't mind, please tell me more about the cart gas tank. I like it.
Also, do you have any porting done to your engine? How do you have those carbs set up?
Thanks.
Carbs are twin 48 powerbombs
145 tops
115 piliots
2.5 N&S
115g spring (im going to put a 95 in it)
Yeah exhaust and inlets on the cylinder have been ported, (i didnt cut out the sleave in the inlet as many do) as has inlet and exh manifold also been ported (& no case porting, just epoxyed the drain)-
Kart tank was an off shelf item- I fitted twin pickups in the back (as can be seen) then there was 2 other take-offs which i used for return & breather, just used the factory clips which held the tank in and found some shorter straps. - hope that helped.
