- Mechanicsburg, PA
ooh i see. looks like i know what tomorrows project will be. one more question about the trim, how did you connect the cable from the lever to the stock unit? i was thinking i would take one of the wheels from a carb and mount it on there .
The plate you see in the picture is the cable stop plate. I drilled a hole through the wheel and used a nut and bolt to pinch the cable to the wheel.
I think I ended up using the choke cable from an SX but is a little flimsy. A thicker gauge cable would be better but this one is still holding up for now.
