The Penguin
triple secret probation
- down by the river
you going to bring it to Somerville this weekend?
oke:
you going to bring it to Somerville this weekend?oke:
Oh I just rememberd. I cant take it to somerville. My carb parts I ordered 3 weeks ago from ATS aaron STILL ARENT HERE!!!!!!!!!!!!
What parts do you need I might have them
i taped off all the sealing surfaces, but the paint i used was so thick that it crumbled under the bolt heads and caused the bolts to loosen-- boat started running like ass, i grabbed the cylinder and you could pick it up off the engine and the cases came apart-- didnt hurt anything-- just had to teardown, clean, and reassemble-- in my case i think it was the very heavy metal flake--- thats what i get for trying to be all fancy
Quick,
That is a VERY clean engine compartment. A man after my own heart. I have always thought things just run better when they are clean.
Nice build.
Scottie Mac
Quick,
Nice build.
Scottie Mac
yes and yes!
I give my boats the full simple green treatment after every ride..then vacuum the engine bay dry...
im with you!!!
hope this helps
My ported 64X
115 low
100 high
15psi pop off
Edit:
Before it was ported
120 low
105 or 100 High (can't recall)
95g, 2.0 N/S for 24psi pop off
I got a couple questions, it looks like that is an 800 crank or is the flywheel just flipped facing out instead of in..
And what carbs are you using? I am building a Big bore 61x (84.5 start bore up to 86.5 last bore) on a 64y case (similar to the 64x) those look identical to mine that I am rebuilding 44's i assume, but the jets i have are pointing me in a differenct direction, 115 low 135 high with the b pipe, the numbers below seem low... mine were what was run on a stock 760 setup wave raider
did this go in a wave blaster?
did you use yamabond on the crank seal?
