Here are some more pix of this "snowball" project. It's my version of a "reverse" quick trim.
I need the nozzle to aim down most of the time anyways, to control the porpoising.
I used a U.M.I. throttle lever a very nice customer gave me, an old choke cable from a Jetboat I had, & a reverse gate spring off a WaveVenture.
Took me nearly all day, but sure beats spending $500 on a kit from Riva.
And here's my effort to adapt a speedo on a Blaster.
Will try it out this w/e & let you guys know if it worked.
Also had to shave down the front of the Ocean Pro ride plate, to eliminate the step it brought.
And also had to use different bolts, & grind a couple of them so they wouldn't protrude down.
I was wondering if anyone had any experience using an extended nozzle? Is it worth the $100?
