SUPERJETT-113 said it's a fletcher brand or something. He had one just like it for the blaster. Other than that it is a new species, lol a missing link as no one had a clue other than him. It was a good box and he bought it from me.
For the hood mod, I chipped out the glue SOFTLY using a Harbor Freight heat gun I got with a coupon for like 9 bucks. Used a chisel as you would use a scraper, but gentle as metton is soft. Make a template for the hood insert using card board. Make it a little bit bigger as to cover any areas you underestimate. Cut the biax to match your piece of cardboard a little over. I then laid out some saran wrap on the garage floor to put a sheet of 1208 biax down and pour some epoxy on it (apply with a fiberglass roller! Rollers rock). Not the best way to set it as it's not really smooth as the saran wrap I put down was in a hurry, but with some thinking you may be able to make it super flat. I used the heaviest biax I could find I think. One sheet is plenty strong. Then the I used a dremal with a sanding drum to get it in... it took some time. I used some expoy dye to avoid the nasty blushing that will occur over time. You want the biax to come to the bottom rear corner so you and put a hole on each side for drains and they will be invisible from the outside (it will drain between the hood seal and the rear corners) and allow for the hood to drain via a 1 inch holes I drilled. The holes in the back(top) are like 2 and 1/4 inch. That was the size of the hole saw I had. The 3 tubes are pool pump tubes from WalMart, but if you know anyone with a pool I'm sure they have some of the blue suction hose that has a bad section you could have. I put them about an inch or 2 into the liner.
The brick helps insure the liner sticks to the middle of the hood. I used a strip of biax around the edge where the liner meets the hood as a seal. It's not as hard as it seems in hind sit, but find as many pictures of the mod as you can and got from there. Thats what I did. This mod is great for keeping water out.
For the vents, cut them out and tape over one side and glass the other side, when it dries pull the tape and do the other side, then feather the top smooth with sand paper. Do the same for the front 6 holes too.
