951 Swap X2
Chiseling away! LED light strip wired in to a motion sensor just like my 750 X2 for better lighting inside the compartment. And another single led tagged into the coil for an easy quick glance to ensure the coil is firing at any given moment
Brand new steering cable with a little modification for the setback 148, and everything sealed up on the bottom. Flipped it back over and ready to wire up the zeel tomorrow. Engine cranked out 150 psi which is 25 over stock, so I think we are in good shape! Getting very excited!!
Well here it is folks. The big bore 951 X2 ! (997cc). Engine is in and cranking over, gonna throw the map on the zeel tomorrow cuz we had some technical difficulties, fingers crossed for the first start!
Jr.
Standing Tall
Staff member
Hot-Lanta
I saw your post on FB. Shows your not getting spark. photo of program is blank, so you will not.
when your i the program screen, in top right corner is spark test tab. Have plugs out and plugged into wires.
use the spark test to ck? If you get spark your good? I can send you a test program to get you running.
the one part I cant help with is the static angle for a 951? Your close, let me know if I can help
P
P
I haven’t uploaded the map yet! I’ll holler at you tonight if I don’t figure it out. This is the map I was gonna use
For F**k sakes we’ve been chasing our tail the last 2 days trying to figure out why it backfired so violently it split the water box at one of the seams. Turns out 2 of the pins on the stator plug were backwards. Finally got it to fire correctly and made a few bangs before we decided to call it a night and walk away while we are ahead lol. Hopefully gonna get a first start tomorrow.
