- new jersey
So I smartened up and got a new set of triple 44 sbn. Problem is, the kawi 1100 case has only 2 pulse fittlings.
I tried teeing off for the mag and center carb with the pto carb on its own but no fire. I guess having dedicated and even pulse lines matter. ( with a tee all pulse lines were diff lengths)
After some research and phone calls I find that I have to drilli/tap for a third pulse. I have a speed plate so easy off and enough room for a drill in blasters bilge. I was told with being careful and a vacuum I can do this while engine still is in the ski.
Will my reeds be directly under the fitting? I really don't want to take off manifold again
