62 t
Protec Pipe Black
Protec Rec Head
Jet works Flow control valve
Tau Ceti Flame arrestors
Reed spacers
Chris Carson Reeds
Msd Enhancer
Lightweight Flywheel by Zero
Blowison tailcone
Impros solas 14/19 extra setback
Removed all casting defects and Polished Shoe and Pump vanes also matched all rings
Blueprinted bottom and filled all bolt holes and seams
R & D intake
Protec ride plate
Also removed choke plates and switched to primer setup
removed oil injection, now using Klotz Oil premix w blockoff
I will shoot the cylinders w ray temp and make sure they are both running the same temperature Results to be posted shortly
