Would you have to attach to the tray some how yet for strength? I've got my glass work pretty much done under my pump but if the plate is the way then I'm all earsMost glass in larger aluminum plates and drill tap during install
That's funny cuz I made some out of 1/2 inch bolts that looked identical lol my real question is the install, like do I grind the foam out for an inch around the insert and put epoxy in first? Then install and glass top and bottom? The inserts come down from the tray right? .......Iowa boy never been around too many ski builds. I know a few people that make these.
Air blair cell
Sounds good, thanks a million for the helpSounds like a little more research on your part. This is how I do mine. I do glass over the top of inserts and around em to keep em put.
Air blair cell
Man that's awesome, I was thinkin in my head how I could do it and not get glass/resin in there, can't wait to go home and work on it. Thanks for all the help!!!You can pack the threaded portion of the insert with clay so epoxy/gflex does not run into them. Then just chase the clay out with a tap.
Can they be regular steel? I turned some on the lathe that look nice but I don't want any trouble down the road
I wondered that, thanks hinkDefinitely not, they will rust in no time.
