FX-1 Advice on installing pump mounting inserts
maxboost
Super tuned
Ia
Hey, I'm in the process of putting a kawi 650 pump in my fx, I'm to the point in my build of installing my inserts that the mounting bolts from the pump screw in to. I've done some research but looking for a few words of wisdom. Thanks
maxboost
Super tuned
Ia
Most glass in larger aluminum plates and drill tap during install
Would you have to attach to the tray some how yet for strength? I've got my glass work pretty much done under my pump but if the plate is the way then I'm all ears
Sanoman
AbouttoKrash
NE Tenn
The gflex works great (@DAG).l've used in several builds.As far as the inserts,l like using stainless blocks .3/4" x 3/4" square.You can use 3/8" thick or whatever you feel more comfortable.A little anal but you never have any issues (it will gauld) with stainless.
Encapsulate the inserts with fiberglass,so it won't leak too.My $.02 :D
air blair
you are the reason
. I know a few people that make these.
Air blair cell
maxboost
Super tuned
Ia
Air blair cell
That's funny cuz I made some out of 1/2 inch bolts that looked identical lol my real question is the install, like do I grind the foam out for an inch around the insert and put epoxy in first? Then install and glass top and bottom? The inserts come down from the tray right? .......Iowa boy never been around too many ski builds
DAG
Charlotte, NC
You can pack the threaded portion of the insert with clay so epoxy/gflex does not run into them. Then just chase the clay out with a tap.
maxboost
Super tuned
Ia
Man that's awesome, I was thinkin in my head how I could do it and not get glass/resin in there, can't wait to go home and work on it. Thanks for all the help!!! :D
air blair
you are the reason
Never did gflex but epoxy I wouldn't think so unless it was like a 1/2 inch thick puddle
Correction: the heat comes from the cure so by that time it's already gelled. Make sense.
Air blair cell
JetManiac
Stoked
orlando
Oem yami pump inserts are awesome and affordable. Brass and they are designed to mount from tray side. We stock them. Blair has one in his pic.
maxboost
Super tuned
Ia
Can they be regular steel? I turned some on the lathe that look nice but I don't want any trouble down the road
