- Tuscaloosa, AL
I will say this with a straight face. I think anyone is an idiot that does not put any floatation in their skis.......... Is your hull built yet?
I thought about this but I wasn't sure if even with all of that packed in there if it would even float a sunk hull. But that ship has sailed since I already bonded the two haves of my hull, so my only option to two part foam at this point. I made my tray as air tight as possible then installed a drain plug for the tray incase I get any moisture.I foamed the circus I'm building just out of the pure fear of losing the thing in some horrific accident. Had to help rescue a buddy's sinking Circus last summer - not something I'd like to experience again.
Even if the hull is punctured or for whatever reason my versiplug max gets stuck open and the bildge can't handle it, the thing will still be neutrally buoyant enough for me to hold it up.
I threw what I could of some round nose foam into the nose of the thing too. Polystyrene in the bottom deck, 2 part US composites 2lb polyurethane in the top deck.
Its maybe 3-4 extra pounds, and some sweet, sweet relief.
Sent from my VS980 4G
This is why there is no versa plug installed yet. I rode a Backie at daytona this year with no bilge and a versa plug, got rolled in the surf and that's all I thought about. Not a good feeling.Remember a versi-plug only works under water. If your ski flips up-side-down, it's a vent to let all of the air keeping your hull floating.
Skis don't sink with you riding them. They sink when the surf nags it.
I almost lost my x2 once. I took the foam out of the hood to clearance my pipe. I was at the brink, wind ripples lapping over the bottom deck, completely submerged. It still had foam on the back and it went down fast. Not a feeling I ever want to experience. Back the , relatively speaking, my $1500 x2 with several hand made mods felt like losing a $20k ski.
Thats a given. Nothing new here, Move on.im a huge idiot![]()
I thought about this but I wasn't sure if even with all of that packed in there if it would even float a sunk hull. But that ship has sailed since I already bonded the two haves of my hull, so my only option to two part foam at this point. I made my tray as air tight as possible then installed a drain plug for the tray incase I get any moisture. View attachment 281820
With out a versa or scupper the only other way to sink a ski immediately would be to blow a hole thru the hull or loose the hood which is pretty preventable. Right?I like the idea of skis straight from the builder with no foam. It really helps the industry. Smart hull builders. Saving the sport one sunk ski at a time.
The indestructible 701 industries nozzle.What nozzle is this?
I get what your saying I just don't want the heavy water logged foam (which will eventually happen) or I would have stuck with a sj hull. I got thicker top and bottom hull halves and was trying to cut down on weight with no foamFoam it. I've seen $20k+ skis dissapear in seconds in lake and surf..
P.S. once foamless ski start sinking, fellow rider cant rescue it or he goes down with it. Bobbing ski with even 20 years old water logged foam will bob to shore itself. Personal experience with a/m foamless ski and old foamed SN.
I probably should have started this thread before I glued the two halves together......Polysterene weighs next to nothing and does not absorb water. This and a couple drain plugs....badda bing.
????? Any one try this before?If your decision are already bonded, couldn't you drill holes for drain plugs and pour in polystyrene pellets? Then just have a mesh screen behind the drain plug so they don't pour out when draining out any water.
Idk if you can buy polystyrene in pellet form, but I'm sure there's an easy way to take a sheet of it and get it into small pellets.
