BrightE's
Paul
- Seattle, WA
I wouldn't mess with beads.
Cut your tray open like you would any superjet and line the bottom deck up to the bond line with pink expanded polystyrene foam from home depot. Or if you want an easier material to pack, buy exdpanded polypropylene foam. Its less rigid so its easier to pack into a tray, and its impervious to solvents and gasoline, which the polystyrene is not. Costs a bit more and has to be ordered online.
Seal up the tray, drill two holes, and top off the gunnels with expanding 2 part urethane from US composites.
Put in drains while you're at it if you haven't already.
Sent from my VS980 4G
