We avoided it on the first few hulls for a few reasons.
One we were told by the designer of the hull not to, his reasons were- the epoxy laminate will flex more than the gelcoat ever will. (stress cracks in gel coat) and it will add more weight than paint.
Instead we sprayed primer over the pva and laid up over that. When sanding we found pin holes and some small bubbles that needed attention. Some of the air bubbles were 3mm across and 1.5mm deep, mainly in corners and tight spots. By far nothing that could not be prepped out before paint. What would happen if you had a small air bubble under gel coat? It may hold up for quite a bit, but in the end it would cause an issue and you would have an angry customer. That is not what we want. Another big reason we opted not to use it was the molds have a ton of "print" in them in spots. Im very happy with the design, and it was a huge gamble buying these sight unseen in Thailand- so we are going to work with that we have for now.
