Super Jet Aftermarket SN waterbox?
what are you sn guys running for a am waterbox, im not a fan of the weight and fact of backfires blowing the glass one apart? iv seen people run rn boxes?
thanks Matt
Midlake Crisis
Bakersfield, CA
I have a Factory Pipe aluminum SN box and love it. I had a couple SN stockers crack and leak (one blew the lid right off), this one sounds great and seems a lot more solid. Intrestingly enough it has no baffle, but it isn't annoyingly loud at all. I was going to use a RN box but it needed a little too much massaging to make it fit, wasn't worth the extra effort to me.
I have the FP on my "friend" ski. It sounds hilarious because I have a stock pipe on with it. It is the most odd sounding thing ever.
tor*p*do
Squarenose FTW
NW NC
I run a dg tri-oval aluminum box in my SN w/modpipe 718 ported 61x
Sounds great, not too loud, nice and throaty
also lightened up the nose a bit!
and I can run it drier than stock
WAB
salty nuts
coastal GA
Just get an OEM RN box, cheapest option for you. You will gave to heat & stretch the exhaust tubes on it, but it goes right in other than that.
mr.fixitman760
if it aint broke, dont fix it
St. Clair, MI
i have an FP RN box in mine and it works perfectly, im currently using it with a type 9 dry pipe and early in the season it got too hot because the previous owner put a carb jet in the water inlet going to the stinger but other than that it works awsome and not loud at alll but still sounds good
BruceSki
Formerly Motoman25
Long Island
Stock RN water box in mine. Easy to install. Fits right in. Heat the long tube and it goes right on.
My next step is a RN long hose and thru hull tube for mine.
BruceSki
Formerly Motoman25
Long Island
the diamter on a squarenose was built to flow the CFM for a 650 motor. Both the long rubber tube and the stainless thru hull tube.
The RN tubes are larger in inside diameter and designed for a dual carb 62T motor.
