- Webster, NY
I suggested that years ago, everyone made fun of me.
haha
a bladder, with a shrader ( tire fill) valve and a pressure guage.
hook it to air hose, fill it to 20 PSI or whatever.
you can check the guage to make sure its holding ( you have safe flotation if its holding Pressure)
and you can deflate/remove and reinforce or do whatever you need inside.
a truck innertube, or something similar, with a heavy canvas bag or something, or heavy rubber bag.
I honestly don't think that it's that far out of an idea. Trying to get a bladder or some sort of inner tube to fill in all the voids would be nearly impossible. Any sharp object petruding would eventually put a whole in them. If the tray area is pressurized then your saving weight and it will still be structurally sound. The only problem is getting it air tight, which honestly I don't see being that impossible of a task. Instead of caring a fire extinguisher your gonna need to have a can of "fix-a-flat". :biggthumpup:
