Another modified Superjet Hull
So I have this extra sn hull that I've started cutting into. Seen other guys post builds so I figured I might as well document this one. Plus it's my first time
This ski had previous footholds done to it as well as new foam in the foot trey but nothing was done right therefore I must do it.
Sent from my SM-G928T using Tapatalk
Roseand
The Weaponizer
Wisconsin
I don't think whoever did this before me did it right. Literally tiny pink blocks all over the damn place.
Whoever did it, did it right. You use the pink EPS foam because it doesn't absorb water.
Sorry I didn't mean the wrong type of foam. It wasn't shaped at all. It was literally a bunch of small blocks everywhere. I was wondering why the tray sounded hollow
I'm wanting to go ahead and get a conduit set for future trim. Where should I install this? And what size conduit?
Finally breaking ground. Have the back end cut. Somewhere between 4 and 5 inches shorter. Next is to start cutting the nose. I will be ordering materials this week.
Here is a list of material I'll be ordering from
Epoxy and resin system: EPOX-635314 42.6oz $71
Ratio pumps for epoxy:EPX-P31 2PC $6.95
Carbon/Kevlar hybrid blk/yllw: FG-CK99050 2yds $77
DBM 1708 biaxal 38" width: FG-170838 2yds $13.20
Roller frames 4" + 7": COR-ROLL4/COR-ROLL7 $5.60
White glasskoter R2O1F(knaps): COR-R2O1F4/COR-R2O1F7 2PC $8.40
I will update this if anything else gets added.
uscomposites.com
Sent from my SM-G950U using Tapatalk
Very nice! Looks real similar to how I cut the back of my square. I think I went a little shorter on the back. Still have yet to finish and ride it. It’s a lot of work.
Thank You! I just checked your prof pic and they definitely look similar lol. Are you rockering the nose?
Sent from my SM-T713 using Tapatalk
Yup shortened and rockered the nose, still working on the nose. I didn’t go with the carter b rocker nose kit I built my own nose entirely too and bottom deck of the nose. Running a round nose pole bracket too.
Lots of photos and maybe a few things you will find useful in my square build you can see and read about here...
http://www.x-h2o.com/index.php?thre...opped-rear-this-website-made-me-do-it.178120/
I am definetely going to check it out later Today. I was gonna ask if you had any pointers for the nose. I didn't plan on using a kit for mine either lol
Some guys make a lot of horizontal cuts on the bottom deck and put wedges in to get the rocker but I do t like that idea for strength and weight reasons. I completely build mine from scratch but it has and still is taking hundreds of hours.
Check out Midlake Crisis "New nose for the square nose",best lookin square nose job I've ever seen.
Some people do that on purpose and put a drain at the bottem of the hull, lets any water that makes it in there drain out after.
I guess I didn't think about that. Honestly can't say I agree too much with it or at least with how this one was done. Literally when you knocked on the foot trey it sounded hollow. And when I tore it open I just laughed cause it pretty much was lol
