Anyone Fit a Blaster Mod Chamber in a SJ?
I thought I remembered seeing this done by someone a while back, but does anyone know how to fit a Blaster Factory B Pipe with a Mod chamber in a Superjet or other aftermarket hull set up like a Superjet? I think there is clearance, but the outlet of the chamber on the Blaster Mod pipe comes out in a different location. Any help/advice would be appreciated. 1722826884967.jpeg
waxhead
wannabe backflipper
gold coast
Use an sxr chamber. They are easier to fit and you have the out let headed in the right direction. Just a bit of hammering and you are done
i believe this kit will work with the b1 chamber. i have new one sitting around from a project i never used id sell.
I think that's what I need. I'm looking to see if I can fit it in a Tigercraft Viper. Can you PM me with what you have to have for it? Thank you.
You can also use the stock sj stinger to waterbox hose with a bushing on the stinger. I have a tnt ss chamber that is very similar to the blaster mod. You'll need to slightly massage the chamber where it rides against the hull about 2 inches from the coupler ring. I purchased the silicone hose and aluminum pipe from Amazon to connect the pipe to the waterbox. Total cost was around 70 bucks.
