- Houston, TX
Did you use a harmonic balancer puller?
Well this flywheel is STUCK hard. I don't know if it's ever been taken apart. So right now I sprayed some pb blaster in there and am calling it a night till tomorrow on my lunch break. Any tips for getting this thing off?
The hammer on the puller send harmonic waves to the flywheel causing it to break its hold on the snout of the crank. Not really hitting it so hard that it knocks it off.The best solution is to use a flywheel puller. There are three threaded holes in the flywheel where you fasten the puller and pushes the flywheel of the crank shaft. Should not be a very expensive tool. Using a hammer is not recommended even if that does the job(poor crank shaft)
Edit, seems that I was a bit late to the party![]()
You have to use a puller...............................
You have not been doing this that long. You will find on day you will be cussing. I have air impacts and there are times where it just does not just pop it loose. Other times right off... even pulled my flywheel of my 23hp Kohler lawnmower engine last spring.I've never had an issue pulling a flywheel..I just use a puller and an impact. 1/2 inch drive electric impact works wonders, otherwise a 3/8 drive air impact should typically do the trick too.
