masterblaster
X-H2
in and of itself yes,but multi spark and dual dig....eh not really
yes you can on epic or flame. keep in mind that if the curves are really different this can affect the carb settings.
Dude if your going to keep making smart ass remarks about things you dont knowabout,at least read the rest of thread that pertains to it,start with post #10
Chris. Is the flame a dual digital setup like the msd?I know the older msd units were single pickup and not digital.The combo of being multi spark and dual dig gives me the smoothest idle and fastest response ive ever had on any ski or ign. I may try the flame someday if this msd ever craps out,this really is a "ingenious" idea for sure with programmable curves and selector switch for 2 curves,makes great sense to me if you ever have to figure out a motor yourself
OCD..Id of never guessed solenoid,but it makes sense,if it was not making a good connection,this could be enough resistance to drop voltage to 10v, why does the ign advance start timing at a lower voltage in the first place?
Add the solenoid to that list as well. We are not sure of it's caused by a bad contact on the solenoid or interference, (electrical noise) from the coil backfeeding to the unit but replacing the solenoid seems to have fixed the cranking issue.IF you having cranking issues, hard to actually turn the motor over, that is a battery, cable or starter issue, not an ignition issue.
ocd,thats cool you did that for scottS he is one cool guy,hes the type of guy that would do anything for ya .ask him bout the time we went out at hugo,just the 2 of us on both his skis,mine was nose crunched from week before. unfortunately they both died,a few min apart half way through the ride...fun long swim in,lol
What engine package are you running yours on? I haven't changed my jetting yet and have run thru several different curves on my SS865. The Enhancer curve leaves my plugs a little rich but still running very strong and safe. The most advanced curve Chucky sent me turns my plugs a perfect shade of brown and absolutely rips. When we first started playing with curves we watched our jetting pretty close bit i have faith now that we are fairly safe within the established confines. If i go anymore aggressive than already established, i will definately verify plugs again. I think the smaller engines may be less forgiving on jetting than the bigbores when adjusting timing.
