jeremy chambon
Need more power
- rockford MI
Does any have a atp for an sj drive line? What do you think about its size/fit, and sound
@OCD Solutions loves them I believe??Does any have a atp for an sj drive line? What do you think about its size/fit, and sound
It's not in an sj but they have an Sxr box and a (sj) boxI had one on my chan. It fit good sounded good and the price was right. I prefer a stock box on a sj though.
From my understand a box won't creat more power like a pipe but if it is too restrictive it can hinder performance.I have a question for people who have bought different box's
I hear fit, sound, price.
But no one has done any testing to stock or other box's out there and give a reasonable performance test.
How many of you would throw performance aside for noise or cost??
Really...We have and I'm sure others have too. Vid taken during testing ATP waterbox. https://www.facebook.com/Air-Time-Products-380194018706753/videosBut no one has done any testing to stock or other box's out there and give a reasonable performance test.
Because like you most people don't put it on the internet, show me your videos...As for not coming on the pipe you are wrong and in fact as the title says the exhaust came off because a jubilee clip was left loose. Tim, I have/had a lot of respect for you but don't assume you are the ONLY person that knows anything, I've had over 25 years in this sport (without a break) and the guy who owns that particular dyno way more than me with thousands of dyno runs and speed records under his belt. Bottom line is our waterbox does work on the dyno and in the water period.There no video of back to back testing, no data to show AFR with both boxes. To make sure jetting was same condition for both tests.
The motor on the dyno was so lean or over porter it wouldn't come on the pipe and the exhaust was so hot I blew a hose.
Don't be fooled there is huge power to be lost in water boxes.
To much back pressure and it will run good on top. Not enough and it won't have any mid and top.
To small and it will be a jetting nightmare.
And will cause engine to flood with water on laydown style pipe
After market buildWhat year boat do you have, there is a difference between to 2008 and the earlier water boxes.
I run the stock water box modified as its cheaper works just as well.
The good thing about aftermarket water boxes is they have dropped the price of the stock water box alot
They can deal with it if it gets in the way of power.It will piss the neighbors off if you dry it out too much.
I added more water to mine to quiet it down but it took away some bottom end. They clear out faster than a stock waterbox so you pick up some good bottom hit.
