I'm finishing up a build and I'm having issues with the top adjustment screw on the B-pipe interfering with the hood. In the pictures you can see how far above the B-pipe the screw sits. Does anyone have a remedy for this? My plan was originally to shorten the screw and lower the raised pad the screw is threaded into, but I'm not sure if this is a good idea. Any info helps!
Thanks, Bryan
Thanks, Bryan
