- Minnesota
Hurry up and finish this already! lol lookin good!
Ed was talking me into a starter foam plane lol, I would love to give it a shot after I’m done spending a fortune on this hobby!!Rc planes are where it's at! I got into them a year ago and it's been a darn good time learning to fly! I'm up to 7 planes now with 2 that have floats for water take off and landings haha. The most fun are the 70mm edf f16 thunderbird jet and the 90mm fa-18 super hornet with thrust vectoring. Highly recommend.
NAPA usually carries some reinforced exhaust.Try them DylanPicking up a noco lithium tomorrow and I think we may have our first start. Just gotta find me a piece of exhaust tube lol.
Oh btw if this one sinks I’m not coming back to shore so whoever finds it first can keep it![]()
Do you have the 60 return jet installed?Started it today
NLP9 is giving me a slow crank unless fully fully charged which is odd for a 400 cranking amp battery.
No hot cables and they’re all new..
When it slow cranks it’s kicking back even with the 20* start retard setting on
Fires up on fast crank and idles alright, had a bad hang in rpm but theirs a lot of air in the fuel line leading to the front most carb.
Changed fuel pumps and I’m going to give it another shot.
Yessir, these carbs came strait brand new from Ed I haven’t even touched anything yet including in-line jetDo you have the 60 return jet installed?
Are you running the jets that Ed installed or did you put your own jetting in it?Not looking so good
Can crack the throttle a few times then itll rev up again like the throttle plate was cracked even with them closed.
Pretty sure I’m pulling air somewhere BUT it idles completely fine and passed a leak down test, don’t think it could be anything else!
It came jetted from Ed, sorry thought I posted the reply. Jetting is within where it was running last time by 5 points on both jets.. more worried about the front cyl revving up on its own after the throttle plates closeAre you running the jets that Ed installed or did you put your own jetting in it?
Well I’d say you’re halfway there but it’s more of a “poor tuner” issue then a primer issue LOLIt's probably the Primer leaking Air into the Fuel Line.
Primer Systems are Problematic.
You should know better.![]()
