DylanS
Gorilla Smasher
- Lebanon Pa
No clue, the issue reared it’s head about 4 minutes later. I believe it’s intermittent loss of spark, I changed a coil because it seemed like I was getting weak spark so we will see if that’s it.. if not guess I’m swapping brains!What caused the issue?
Bad Tuning? Primer? Bofth?![]()
This case was from my uncle trying to ride the ski and killing my battery until the engine was slow cranking. Kicked back on a slow crank and sheared the key. Guy rides a 1000cc DVX and says “wtf this thing is stupid I can’t get up on it” because he couldn’t rest his arms on the lower tray sides lolHow does that happen? Is it from high compression and starting the engine? Or does it just hit so hard it will twist the crank inside the flywheel?
Actually ended up being 3 bad coils consecutively so that was cool!I mean zeels are not the end all be all solution. I too am on my 3rd zeel cdi haha
Salt water or fresh water?I mean zeels are not the end all be all solution. I too am on my 3rd zeel cdi haha
Little bit of both. Water did get in the ebox each time. Had to really seal it up. The extension cable got water behind it and broke a pin on the connector on the 1st one. After that I quit using the cable just the rubber plug. Both ao2t cdis that went bad had water intrusion on the sides of the sealed area where the wires come out. I'll get some pics and post them. Not trying to derail the superfreak thread though hahaSalt water or fresh water?
all good man I’ve been derailing it myself! It’s about wrapped up besides final picsLittle bit of both. Water did get in the ebox each time. Had to really seal it up. The extension cable got water behind it and broke a pin on the connector on the 1st one. After that I quit using the cable just the rubber plug. Both ao2t cdis that went bad had water intrusion on the sides of the sealed area where the wires come out. I'll get some pics and post them. Not trying to derail the superfreak thread though haha
She’s a little too twitchy for me to chase big wake with!1200 total loss a little too much power?
