Axles on. Cabosil, epoxy, dye.
Tray removed
Some corrective body work, but I'm out of time so it'll be as it is.
Pissers installed
Didn't like where the front wheel was so I used the piece I cut out of the tray to move it forward by 1 bolt pattern. Now instead of the front bolts holding on the pole, the rear ones do and the old rear bolts support the plate. Also, in addition to the plate, I added a second spacer washer to bring the nose up a total of approx 2mm.
Pole installed when the wheel was. Had to change out the front bolts to hex because I couldn't get the allen in with the pole together.
Tennis racket grip tape over the PVC.
