Because I'm lazy Backie Chan build
yamanube
This Is The Way
Staff member
Mandalor
What are your thoughts on your KP pole now that you've been running it for a bit?
No complaints, I don't think it has the ability to be adjusted out at all (the way it is designed requires the poles to be run all the way into each end) so once the tubes are cut, you can only go shorter. Other than that it looks great, fits great and has had no issues.
yamanube
This Is The Way
Staff member
Mandalor
Put some new reg numbers on thanks to @bware52
index.php
