Best Li-Fe battery I have seen so far
Waternut
Customizing addict
Macon, GA
That's the cheapest one I've ever seen by far. Might want to do some research on that battery before you buy it. Most 12 cell Li-Fe (A123) batteries are in the $300-$400 range. If that's legit, I may be upgrading this summer.
sjetrider
I do not like this ". Do not charge or attempt to maintain charge with a trickle charger" Although my trickle (2am charger) does shut down charging once fully charged I could see where this would be an issue. Also this "Do not allow the battery to be completely drained, this will damage the cells." could be an issue with T/L users such as myself. This battery will prolly funtion perfect for someone running a charging system though.
I do not see why this battery should be much different charging wise than a Deka or an Odysey but according to the staements mad in there websight they are different.
Aircraftsalz
Thrust built Dasa Power
Off site
Order one from Solo, 8 cell to try in my new surf freak.... Will test it first on my 1000 / TL ski & report how well it holds up & how long etc on a days ride.
Can't beat $160 shipped
Waternut
Customizing addict
Macon, GA
Well you shouldn't need a trickle charger at a voltage loss of 10% per year. Think of it like a cell phone or laptop. They may be lithium batteries and aren't supposed to have a memory but if you keep it connected to the wall all the time, it won't last very long when you do take it off. That's a guess but it makes sense...
Also damage typically occurs when the cells drop below 2v each so 8v total. Your bilge will barely run at 10v so unless you leave something on overnight, you'll be fine. Cycle time is supposed to be between 1000-3000 cycles. I know I've owned my Deka for about 2-3 years and I haven't come close to charging it even 1000 times.
One more consideration that I've found wierd. The site says to use a normal charger but many normal chargers are designed to stop charging at roughly 12.5v-12.75v and aren't true peak chargers that can detect voltage drop once fully charged. These batteries are fully charged at 13.6v and not ~12.6v. That's roughly a 8% drop in useable capacity or an actual A/H rating of 4.2 a/h for the 8 cell battery and a 6.3 a/h for the 12 cell battery.
scotts2t
Head Woop!
Lake Erie
I have a shorai battrery, it weighs 1.35lbs has 155 cca and works great. I have MSD total loss and this battery works for 2 days of riding without charging.
