F
Freestyleriverrat
Guest
I would say you could go a little farther with the lamey but your 4mil stroke is hard to beat. I would put it up against any stock stroked lamey and even alot of stroked ones. Speaking of that I'm on my way over to get some druel on it right now.
I really want to ride one of those boats. I hear good things about that set up. But then again you are comparing a 4mm stroked motor to a stock stroke motor. Just keep in mind that you are maximizing that 61x cylinder set up where the lamey is pumping out that power no problem and there is only room for improvement. But it does come at a cost. You will spend about anouther $800 more for a ported lamey set up than it costs to do the 4mm stroker 61x motor.
