RiverRat
- Louisville, Ky
what do blackjacks go for?
the 2k is with rad valves and manifold
On the manifold side of things I switched from old style R&D manifold w/ v-force reeds to the intake system that they use on sets of full spec 48's. I achually think the v-force gave me more power. However, the Rad valves seal better IMO. The v-force w/ the plastic cage and carbon reeds justhad a little bit of clearence between the cage and the reed petals. If they made v-force w/ an aluminum cage that would be nice. The M-16 set up is very nice as well but I can't justify dropping the bread on a new set of cages just for grins.
Here is a comparison I did: 44's vs 48mm Riva vs 48mm Full Specs: http://x-h2o.com/showthread.php?t=5088&highlight=riva+full+specs
