- Tuscaloosa, AL
Hey that's a stock class secret. shh. shh, shh:sneaky:
That is something that Bill Haig is always saying........ If it is perfectly flat you dont need a gasket!!!!!!!!!!!!!
The 750 flywheel's are all the same from 93 & up. I know I've tried them.
All 750 stator's will work with 03 and under cdi's. I know I've tried them.
I am pretty dang sure all green engines are big pin.:biggthumpup:
Thanks for the help, I think or the confusion I'm still not sure:veryhappy:
Zig my motor is teal green. It does have 12 bolt holes but only 10 have studs with nuts. The other two holes are on the side of the intake hanging off the side with nothing to bolt to.
Explain?How can I tell which engine I have? It's a silver case small pin engine with the 10 hole intake pattern. And it needs a lot more work than I thought, but thats another story.
those 2 holes could be for external fuel pump mounting..... if youre in to that sort of thing.
If you compare cases for big and small pin, there is not even a place in th casting where the two inner studs would be, on a small pin case. Big pin is only the set of cases that have them.
Is this definate? I always thought I had a small pin in my 92 but mine has the inner holes for the intake manifold. I don't use them but the casing certainly has the holes.
